Moroso Catch Can up close
Old 12/1/09, 12:02 AM
JedCranium's Avatar
I purchased the Moroso Catch Can from Lethal Performance here are some pictures. I'm going to install it in the next month or so as soon as I get a custom AN fitting that is being made for the Kenne Bell blower.
The kit includes...
This unit is actually for the Hemi Charger but with a little work it will work fine for the stang. The two side holes use a 3/8 NPT.
I plan to replace the supplied brass hose fittings and go with AN fittings (Mr Gasket/Shadow Series) and a breaded line from Airoquip.
More to come after the install stay tuned.
Jed
Old 12/1/09, 12:44 AM
LEO_06GT's Avatar
Looks nice. How big is it? Looks like a couple inches judging by the pic.
Old 12/1/09, 12:57 AM
JedCranium's Avatar
It measures 4 1/2 inch high from the nut bottom to the top of the can. Diameter is 3 inches. It's fairly compact it holds at least 4X the volume of my Home Depot thing. Plus it's ez to purge with that valve drain and don't forget the bling factor!
Old 12/1/09, 01:20 AM
06GT's Avatar
What is this, an oil separator for the PCV circuit? How much?
Old 12/1/09, 04:25 AM
IHVOCD's Avatar
Thats nice! What do they cost??
Old 12/1/09, 05:49 AM
Doogie's Avatar
Thanks for sharing as I have been searching for a small, but decent quality catch can and this one meets both those requirements
Please keep us posted on how the install goes!
Old 12/1/09, 06:23 AM
I don't do trannies
or rear-ends anymore!
EagleStroker's Avatar
This has your name all over it Doug! Looks great Jed
Old 12/1/09, 06:47 AM
69Mach1-409's Avatar
Looks like UPR's, but smaller - with a drain plug & hose.
Old 12/1/09, 07:21 AM
Doogie's Avatar
You are no help Robert!! The size is definitely right. But with the exit hole being on the side and not on the top, this one probably won't work given the odd location of the inlet on my SC
Old 12/1/09, 01:24 PM
JedCranium's Avatar
Yes it's an oil separator....
I think it cost me $145.00 for the "kit" a little pricey but it met all of my install and visual requirements. I've been looking for this for maybe a year; I first saw it at SEMA this year. I bought it from Lethal Performance the stock number is 85472.
Jed
Old 12/1/09, 10:45 PM
NastyStang113's Avatar
Nice pictures, did you use a light box or just a white paper and good lighting?
Old 12/2/09, 12:00 AM
JedCranium's Avatar
I did a quick and dirty light setup using a Dyno Lite 1000xr pack and two strobes heads bare bulb. I should have used a couple of soft boxes then the white would of been more pure white. But I was lazy I just bounched light off of my ceiling. My soft boxes are buried under a bunch of car parts.
Old 12/2/09, 04:54 AM
colbymh's Avatar
For those looking for one, go with a BKU oil separator. Brett at BKU will custom make it per your mods. It's pretty identical to the ones you can get from Steeda, however he alters the setup for your needs. Plus it looks good for $45.
Old 12/2/09, 07:27 PM
jasongt06's Avatar
How do you get in touch Brett @ BKU ?
Old 12/3/09, 01:59 AM
JedCranium's Avatar
Are you talking about this unit...>
Dude there is no comparison to the Moroso unit. This is exactly what I'm getting away from a Home Depot style solution. This is just an off the counter part (w/ to many adapters) that is semi effective and leaky at times if you run synthetic oil. Cost effective yes, but effective MEH. If you're motor is blown that's even more reason not to go down this path. I know a lot of people take this route but it's not for me this unit doesn't raise the bar to me as a separator, plus it's FuGly!
Old 12/3/09, 05:39 AM
05YellowGT's Avatar
I have the Steeda unit and it is basically the same as the BKU , except it doesn't have the fittings to increasing the size for the larger hoses. It does look like the **** on the bottom is metal on the BKU unit , where as the Steeda one is plastic and has already broken so I don't drain it through the bottom. It's the same size as the Steeda one and I empty mine every weekend to keep oil below the filter and that's only a couple of table spoons of oil. Plus the bowl is plastic and I unscrew it to empty the oil so I'm always worrying about breaking it. Also I had to buy a supply of O rings for it since they don't last long with the oil. I've been planning on changing it for some time and I like this Moroso one the best ...
Old 12/3/09, 05:52 AM
fdjizm's Avatar
I am looking into these catch cans.. do you need two? one for each valve cover? i get that from these ebay pictures...
Passenger side
Driver side
Old 12/3/09, 06:04 AM
colbymh's Avatar
Yes, but no. You cant go buy the parts from home depot, because they are not rated for oil use. Now, I cant speak intelligently on the matter, but trust me if you talk to Brett you will not be disappointed.
I prefer to see how much oil is going into the catch cup, vs guessing, It's simple to drain and has never leaked a drip.
Old 12/3/09, 06:05 AM
colbymh's Avatar
865-366-7532
Old 12/3/09, 07:15 AM
Passenger side
Driver side
I believe that's the UPR one. You only need one for the driver's side and make sure it's 5/8ths fittings & hose not the 3/8ths they normally send you.
Quick Reply: Moroso Catch Can up close
